Nouveau logiciel opérateur (firmware) 3.0
Je viens de voir passer ceci
https://www.l-camera-forum.com/leica-ne ... ium=E-Mail
La liste est longue :lol:
All Improvements
New top features
Up to 35% faster writing DNG files to SD card
Optimization of the writing process allows to reduce the time needed for saving DNG files up to 35%. This allows to be quicker ready to continue shooting after a burst session.
Optimized Autofocus
MF-/AF-control optimized
Autofocus reaction time is shortened
Improved AF tracking of objects with SL lenses
Improved: Zooming while recording video
Improved: AF field chances while recording video
Improved: AFc while recoding video
New firmware for lenses is included
Improved accuracy of the focus position
Improved AFc accuracy if an object moves towards the lens
New firmware for the VARIO-ELMARIT-SL 24-90 f/2.8-4 ASPH.
New firmware for the APO-VARIO-ELMARIT-SL 90-280 f/2.8-4
Bugfixes
Additional improvements
Store DNG and JPG on separate SD cards
Independent exposure control for video and photo mode
New video frame rate 24fps for 4k resolution 3840 x 2160 px
White balance ‘flash’ improved for use with studio flash system’s modelling light
Electronic shutter mode for shutter speeds from 1s – 1/16 000s for silent shutter release (ISO50)
Exposure preview in M-Mode improved for continuous preview
Improved usability in play mode when zooming to 1:1 (100%) , location gets stored to easy access the same location
Improved flash behaviour for AutoISO setting
Improved behaviour of flash units in continuous burst shooting mode
New options for customization
Swap the dedicated exposure controls of the front and back dial
Current control setup of the front and back dial is shown on the top display
Renaming from T-Mode into S-Mode
New option for AF Tracking “RESET”: Start position of the AF tracking is fixed on a specific location which can be adjusted by the joystick.
Graphical User Interface of the multi selection and delete functions improved
AE-/AF-Lock Button can be assigned to magnification for a quick visual check of focus position
New option to show the focus distance in feet or meter
Automatic detection of Leica M and Leica R lenses can be turned off
Video resolution/framerate can be assigned to the personal favorite menu
User experience increased: the “OK” button on any keyboard input screens is touch sensitive
Audio in/out levels can be controlled directly by left/right joystick on the histogram screen
Several minor improvements made on graphical user interface
New default behaviour: the function “Access menu in EVF” is enabled by default. This function enables the upper left button while looking through the electronic viewfinder. Either menu access and quick access to custom functions is available now by default. For users experiencing accidental presses of the upper left button by their nose – it is recommended to disable this function in the “Customize Control” menu.
Bugfixes
Any shutter speed limitation for any manual focus lens is deactivated
Improved stability for tethered shooting with Leica Image Shuttle 3.6
If an USB connection is detected by the camera, the warning of a missing SD card is hidden. This allows to use Leica Image Shuttle and Adobe® Lightroom® Plugin without an inserted SD card.
For Leica M and Leica R lenses the real-time display of the established aperture is hidden
Leica SL APP
Support for DNG file download
Shutter release by pressing the volume button
Vibrate on shutter release
dielcoluma
Depuis le 13 jan 2013
MAUGUIO (34)
Merci Robert :content:
du M EV1 (Cron 35AA+Noct 50ASPH+Lux 75+Lux 90+WATE) du SL2 (Cron 21&35&90, 90-280, 24-70) du R (Lux 35+Cron 50/90+Apo180)
Merci Robert, je vais mettre à jour mon SL.
Après installation du nouveau firmware 3.0, j'ai un problème d'affiche de l'ouverture avec les optiques M.
L'info ne s'affiche pas dans le viseur, et lors de la prise de vue, ne correspond pas à la réalité.
Déjà qu'avant l'info dans le viseur était farfelu, mais là plus rien...
Avez-vous le même problème?
J'avoue n'avoir rien fait...
D'abord, parce que je n'ai pas eu le temps et que d'autre part, la liste est longue, mais je ne vois rien de "décisif" !!!
Je viens de lire les amélioration, et on voit ceci...
Pour les lentilles Leica M et Leica R, l'affichage en temps réel de l'ouverture établie est caché. MDR
C'est du vice (caché) !
PASQUIER
Depuis le 23 oct 2009
BOURGES
A propos de cette mise à jour longue comme un jour sans pain, quelqu'un peut il nous apporter un retour d'expérience sur la capacité de transfert Wifi du boitier, par comparaison avec CANIKON Pro en usage sport ou reportage intensif ?
J'ai lu que SONY A9 proposait une solution qui ne semble pas ravir l'attente de réactivité des photo reporters ?
fabrice deutscher
Depuis le 2 juil 2009
Paris 3e
Quand je vois le temps que met mon iPhone pour envoyer -via AirDrop- une photo d'à peine plus d'un mégaoctet vers mon Mac, je me dis que c'est pas gagné avec un DNG 36 fois plus gros...
ferryjeanloup
Depuis le 29 mai 2008
Pourrières,Var
Maj faite avec ce nouveau firmware
Beaucoup de nouveautés
L'obturateur électronique est bluffant: silence absolu!!
Mise en route et accès menu plus rapide
Premières impressions excellentes
Jean Loup
Merci. Je vais essayer ce WE :smile:
+ 1
starwolfy
Depuis le 22 jan 2012
Paris / Cergy
Cet update...avec les prochains objectifs E67 qui vont arriver en fin d'année me donne presque envie de retirer mon SL de la vente...même si malgré tout je ne l'utilise que trop rarement.
Actuellement en vente:
Conclusion : il faut l'utiliser :lol:
Retourner vers Leica SL
