M240 : firmware 2.0.1.5
hugues33
Depuis le 12 nov 2007
BORDEAUX
En approche sur le site LEICA (lien inactif pour l'instant) :
Sur LEICARUMORS :
Stef.B
Depuis le 9 mars 2010
Espérons que la stabilité sera améliorée car il m'arrive régulièrement de devoir enlever la batterie pour faire repartir l'appareil... (très souvent après utilisation du liveview).
Stef.B
Le firmware est officiel :
http://fr.leica-camera.com/Service-Supp ... uage=68390
Touyout
Depuis le 3 août 2012
Mons
Et voici ce qui est la raison de cette mise à jour... installée chez moi à l'instant...
Pas mal de chose quand même...
Improvements – Leica M (Typ 240) Firmware Version 2.0.1.5.
• Improved description of the lens type in Exif-Data
• Live view is now possible with every lens (including older screw lenses via an adapter) using
“manual lens detection”
• A “Video off” option is now available in the Set menu (see submenu item “Video recording”)
The M-Button on the Top-cover is deactivated when this option is chosen.
• The Horizon (level) is now visible in Live View, overlaying the live image. This additional infoscreen
is enabled using the menu item “Horizon”
• New menu item “Exposure Simulation”
o Exposure simulation -> Permanent: Live View accurately shows image brightness
according to the shutter speed and aperture set in manual exposure (as long as the
chosen exposure time is shorter than 1/30s)
o Exposure simulation -> Release button half-pressed: Image brightness in live view is
adjusted for best visibility, regardless of the actual exposure.
Half pressing the shutter button shows the actual exposure.
• Extended Auto ISO options
o All Auto ISO options are now visible using the ISO button
o Extra options for “Maximum Exposure Time” - 1x, 2 x, or 4x focal length - can be selected
to help avoid camera shake when using auto ISO and long lenses.
o “Auto ISO in M mode” is now offered as an option. This varies ISO sensitivity for correct
exposure when shutter speed and aperture are set manually.
o Alternatively the camera chooses the previous manually chosen ISO speed
• Crop marks
In Live View, new crop marks for 3:4 / 6:7 / 1:1 / and 16:9 aspect ratios can be displayed. By
pressing the up/down keys, the crop marks are superimposed on the live view screen (without
additional information)
• Korean language
Korean is now available as a menu language
• During video recording, 1/25s is now used instead of 1/24s. This reduces flicker effects with
50Hz mains voltage
• Exposure bracketing settings are now saved when the camera is switched off
• Direct exposure correction
An “EV correction” option in the menu enables direct adjustment.
So EV compensation can be altered by turning the thumb wheel, without having to press
additional buttons.
• New Light Metering Mode “Classic / LV disabled”
In this mode, only Classic light-metering is possible; the LV button is disabled to avoid the
activation of live view by accident.
• New menu item “Focus Peaking”
For improved visibility, the color of focus peaking can now be set to red, green or blue.
• Better display of GPS location data
Position is now shown for JPG files in Adobe Lightroom®
Where the GPS signal is weak, the last position is now deleted after 5min instead of 24h as in
previous firmware versions.
• Bugfix in Live View at high temperatures
Occasional malfunction of Live View at high temperatures has been fixed
• Bugfix in light metering (Live view)
• Bugfix regarding sensor cleaning function
Apple, le beau et le bon matos...
Savoir gérer ses frustrations est la plus grande qualité de l'homme civilisé.
MaximeL
Depuis le 25 sep 2011
Bon Boulot Leica.
Bon, on enlève le bouton M, le bouton en façade, le bouton LV et on a un M240P :)
Manque plus que les LEDs du cadre dans le viseur en permanence et c'est le TOP.
Plus sérieusement, j'ai fait quelques tests rapides, le firmware semble répondre aux attentes.
Pas de plantages, mis de bugs pour le moment.
hugues33
BORDEAUX
Avec le prochain firmware, les boutons M et de façade seront paramétrables.
Bon, installé, c'est OK sauf que tous mes réglages ont disparus : à refaire.
Bravo à LEICA pour la correction d'expo directe à la molette et les isos auto en manuel.
:manif:
Bjeau
Depuis le 5 avr 2013
Merci.
Bon, on va tester tout ça.
Un conseil : pensez à sauvegarder d'abord vos réglages utilisateurs car vous allez les perdre en faisant la mise à jour.
Photographiquement vôtre,
Ce point ne donne pas envie d'installer ce nouveau micrologiciel ! En restant plus de 5 minutes dans un bâtiment, on n'aura plus la position GPS, cela me semble idiot comme délai.
Stef.B
Mise à jour faite.
Déjà plus de ralentissement (freeze) pour visualiser les fichiers à 100%. Progression fluide jusqu'à 100 en tournant la molette.
D'ailleurs ça serai pas mal qu'il fasse comme chez Nikon : en mode visu, en appuyant sur le bouton central du pad (ici "info") on obtiendrait directement l'agrandissement 100% pour voir si la photo est nette.
jjbrugger
    Enfin
Depuis le 2 déc 2013
suisse
Bonsoir, installation ultrasimple. Enfin un firmware qui permette de desactiver le bouton video ainsi que le live view , bouton que le bord superieur du half case ne cessait pas de mettre en marche!
Leica a donc bien adapté son firmware aux desirs de ses utilisateurs, contrairement a Nikon qui sort un D810 sans nouvelles idées, poussé par un maketing obsolet! Il nemanqueolus qu un viseur EVF en metal, moins cheap, et le M 240 aura ateint la maturité. Quel bonheur. :diaph:
JJB
pascal_meheut
    Rep : Enfin
Depuis le 9 fév 2005
Je préfèrerais un focus peaking mieux foutu, une position de loupe déplaçable, une résolution supérieure, pas de "noir" lors des prises de vue mais on peut aussi préférer d'avoir du métal...
stilgarna
Depuis le 4 août 2011
Thoiry (01)
Avec les nouvelles couleurs de peaking, le voit-on mieux dans l'EVF, parce que l'ancien était invisible (en tous cas pour moi)
pascal_meheut
Je ne trouve pas. Je l'ai essayé ce matin avec un 180mm/4 R et c'était toujours aussi ridicule : invisible sans loupe et trop petit avec... Apparemment, les gens qui conçoivent cela n'ont jamais vu un Sony A7 de leur vie.
stilgarna
Thoiry (01)
En effet, la seule chose que je lui trouve au peaking de Leica c'est d'être plus précis que sur tout ce que j'ai utilisé d'autre, mais tellement peu pratique que c'est quasi-inutilisable (pour moi toujours)
Il ne lui manque qu'un vrai EVF à ce M. Dommage dans cette gamme de prix et ça parait tellement évident qu'il doit y avoir un souci technique derrière.
Sinon Leica manque de clairvoyance sur ce point, ce dont je doute fortement...
hugues33
BORDEAUX
J'ai essayé le bleu : c'est encore moins visible que le rouge.
